From the compressor maps of the real GT3071R it should get there but I wouldn't count on it being responsive in large housing single scroll form . Didn't you used to say that a HKS GT2835 Pro S hit the straps at about 280-300 Kw because its the same compressor wheel just without the cropping on the turbine blades . I do have one idea on ice but no hints just yet - pending ...
GCG was supposed to have had the GT3076R 52T though being a special order item it may not be discounted like that other IW GT3076R 56T you mentioned recently . I imagine its cheaper than HKS and you don't end up with the wrong turbine housing .
How did your friends 0.87 A/R housing go ?
Cheers A .
https://www.sau.com.au/forums/topic/161904-gt3076r/page/2/#findComment-3202043
Not sure.. :) I do know Grepins GT2835ProS had boost drop issues over 270-280rwkw but he did manage to push over 300rwkw with working on improving the motors airflow via plenum, cams, exh. manifold etc etc. ~313rwkw from memory. If he were to hold the wastegate shoot power would shoot up over 300rwkw, possibly hks's wastegate flow is just a little too good once then pressure builds up behind the flap blowing it open.
So if thats the case and they are the same comp wheel which I wasn't aware of then yes it should do it with no real problems. :)
But from what I've seen its definitely not possible on a stock cam'd motor.
Cheers A .
Steve with the .87? As I said above it made 320 something rwkw on a shade over 20psi. Its been some years so the details are beginning to fade. :) But it did go well and appears to hit the ceiling of what a few other GT3076 and hks3037ProS tend to make and initially he complained of lag from the .87 which I believe was sorted with cams and a better tuner.
He still floats around on these forums from time to time.
https://www.sau.com.au/forums/topic/161904-gt3076r/page/2/#findComment-3202119
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
    • This is the only point I can access with any floor jack and my car is SUV height - What's the actual suggested alternative here? I have also driven up on blocks in the past, but lets say you have a problem and the car is on it's wheels already and can't be driven up/off anything? Not a huge fan of bits of wood being spat in random locations either (it hasn't happened, but what-ifs occur) Perhaps I would also really enjoy having a quickjack :p Time to google quickjacks.
    • The wires look to be a healthy gauge, more than I would think the pump needs. I guess another concern is if the FPCM will be happy with the extra current draw. I have heard they are a bit sensitive.
    • It will be fine. The real question is whether the existing wiring is fat enough for the current drawn by the bigger pump. The 342 is not that hungry, but it will be well worth pointing an IR pyrometer, or even better, a thermal camera, at the pump hat wiring when it is running, just to make sure. Or, you know, just touch it to see how hot it is.
    • Hi guys, Sorry to revive such an old post! The fuel pump in my M35 has finally given up, the car has been sitting for 3 years so I'm not surprised. I bought a Walbro GSS342 of Scotty some time ago, so I'll throw that one in. My question is, if my car has no performance mods at all, do I need really to mod the wiring to supply constant 12V? or will the new pump be just fine at the reduced voltage at idle? Thanks guys..
