  • Replies 132
depends on wat rear housing wat you use but yer should be 300+ rwkw
ok whatever even with the smallest housing .64 u can get 300rwkw with 13-15psi! opps and cams
cheers
and i dont think i deserved that warning.... but on the other hand i dont really care..
cheers beer baron
https://www.sau.com.au/forums/topic/162228-300rwkw/page/7/#findComment-3110558
omfg.... USE THE SEARCH BUTTON, or read the FI forum. We've been talking about 300rwkw all damn week!
http://www.skylinesaustralia.com/forums/in...80&start=80
maybe YOU should USE THE SEARCH BUTTON, this "300rwkw" thread was created long time before yours.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/7/#findComment-3112170
Um^^^^ who was that aimed at.
doesn't matter if mine was created after or before this thread.
There must be about 100 threads getting around on people who have achieved 300rwkw+, and there is even plenty of cars posted in the dyno results thread.
No wonder this thread has gone to shit, judging by some of the replies.
Some people need to wake up to themselves.
https://www.sau.com.au/forums/topic/162228-300rwkw/page/7/#findComment-3112230
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
