Apexi FC Tuned For $2200?
Guest INASNT
u can get new pfc and hc from greenline for around$1450 now!
Where do u think all the aus shops get there stuff from?? they just add their 30% profit margin to the stuff and sell it here!
I am getting all my stuff from japan, u save big bucks.
and nengun is the 1 i got my pfc from 2
Hey just thought I'd add a bit to this post I ordered my PowerFC, Hand controller and Boost controller (also bought exhaust cam gear) from nengun got it bout a week ago. Got all the above for 155000 yen which worked out to be roughly 2114.69 Tried greenline aswel but Nengun were cheaper in the end and they have better insurance for the postage. Gonna go see my mechanic today to sort out installation and tuning prices.
Good luck with yours
Chris
Guest Sim32
hmm 2200 i know whereu got that quote. start in a c?
ha ha..does very good work but, at a price however..
2200 for AVCR...id rather spend that sorta dosh on a ful sik 2530 or something, but thats just me..
im pretty sure u can get it installed and dynoed for 1800
tried fast and the furious? Kp performance? hardcore race, mazfix?
heaps of joints, just shop about and price match :P
Guest 382 GZV - 4 Door R33
Sim,
did you check out the place?
I am just going to put in the new PFC for a while and run base map. In July, have to go up to Gladstone for Uni placement - there a guy up there who's s'pose to have set up heaps of PFC's (and loves them). Apparently, he does it for $280 on dyno and all so that means a total $1665...pretty happy with that.
Steve
Guest INASNT
Originally posted by 382 GZV - 4 Door R33
Sim,
Steve
do not run with the pfc base maps, they r tuned for 103 octane fuel and your car will ping and the check engine light will keep flashing
Really?
I had only thought of running the base maps (as seen in HPI 21 P.29) because I thought it erred on the safe (rich) side. I don't think I'd run base maps if they will stuff my car up - should I retard a little at first or wait for full tune or are is the map 'OK' to run?
Steve
Guest INASNT
i just pulled my safc out and am running the stock comp while my pfc sits in my room. I was told that even the base pfc maps since they r for 103 octane fuel are no good even with 98 octane fuel since the maps r so aggresive. U could always change the maps to make em less agressive but i wouldnt take the chance.
Guest INASNT
Hey inasnt...since your's is 2nd hand from nengum (japan) wouldn't that mean that the map already on it was tuned to suit some modded skyline in japan? Or was it base map just like what comes on new PFC?
Steve
dont know, but its quite simple to put it back to factory once installed! u got a h/c also dont u?
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
