Wanted To Buy - Mobile Phones - Working Or Broken!, Will Pay Cash - Any Condition, Even In Pieces. Will Buy In Bulk
hey everyone,
last time i put up this ad i was flooded with pm's and have made some great ongoing contacts which I deal with very regularly (some even weekly!) - so im hoping the same success from this post :)
im looking to buy any working or broken mobile phones in any condition, even if completely stuffed or in pieces. preferably nokia - but will consider other models. looking to buy in bulk. and will pay cash or via direct deposit if you are not located in sydney (and we can organise pickup)
please PM me, or call me on 0402-487-085 and let me know what you have and your asking price. majority of phones will be used as parts for my mobile repair business so even old models are considered.
would also be great if any of you guys out there that work in phone shops that can get them all the time are interested? because this is not just a one time offer, looking to buy ALL the time for as long as you can supply. can never have enough parts.
so dig through your draws, ask around and do a round up - get all phones you can and i'll pay you cash
im located in sydney, so may be able to pick up depending where you are located - otherwise i will pay via direct deposit.
thanks in advance.
Edited by 350z
I have a broken nokia slide phone - cant remember the model name, the screen is dammaged but phone works perfectly, one of the newer ones with the large screen and buttons, screen slides upwards to open up to the keypad, I also have a completly working LG u8138, will trade them both for a new phone, preferably nokia, with possible cash adjustment your way. Will find model of broken nokia tomorrow and post it here.
Or, you can have them both, make an offer, if its enough to signifigantly cover the purchase of a new phone ill probobly take it.
just replied to a stack of PM's - so check your inboxes please! :stupid:
2 more deals definately prepared - thanks guys!
please keep the offers coming :)
cheers!
chris.
