for sale is custom matallic blue r32 1993...resprayed inside and out even the engine is colour coded (silver and blue)..everything done to perfection got a r33 gearbox (custom gearbox mounts), struct bars front and back custom 3" exhaust with xforce tip, also hybrid/saber copy frontmount, saber boost gauge, heavy duty exceedy cluth, g'ready turbo timer, isc susspension worth 1500 and ajustable camber arms for the rear...kenwood speakers front and back with kenwood headunit worth 400 and kenwood amp. a lsd mechanical diff, walbro fuel pump saber air filter, r32 gtr interior and bonnect and the list goes on 5 months rego asking 12000ono thanks jamie 0422264779 call after business hours. gtr bonnet never been in a accident..
Edited by lil_jaymeeh
https://www.sau.com.au/forums/topic/162957-nsw-gtst-32-custom-blue/
You wouldnt have driven across maybe ryde bridge or the next bridge across would you? because if it was you, sounded like your muffler was missing and then it felt like my ear drum exploded! Looked damn similar to your machine ..
Sounded sexi tho .. and all I could think about was your car on the way home - then my searing headache :@
haha thanks mate but sadly wasnt me! my car is a weekender...my car is pretty quiet which i like also...im from out west liverpool area
  • 3 weeks later...
  • 3 weeks later...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
