well wing or no wing, the skyline looks good both way depends on your taste and how you want your skyline to look like. right now i decided to have a wing ^^ makes it look more sporty and faster, with out wing i rkn more classy and mean as u siad
Is it $150.00 painted and installed? If so, I'll be seeing you this weekend!! I like how it emphasis the rear more... nice
Are you serious mate? Good luck getting anything even painted for less than that price let alone fitted AND supplied.
I like the drift/stealth wing follows the lines of the car nicely and makes it look nice and sleek.
At a guess, around $300.
Thats weird, for a genuine GTR wing only $300? You sell them for $350 on your website and their fiberglass not pastic... no led for the brake light either...
I know i'd never sell mine for $300 :nyaanyaa:
Your wing is a 2nd hand, PSI's new.. that's the difference.
It's a normal GTR wing? For Real??
I thought it looked a little bigger than a normal GTR wing. :)
Its an extension for the normal GTR wing.
The GTR wing we sell is very competitive compared to others around. I personally cannot see why a wing would be worth more than $350, but that is up to the person buying it.
Yes we could, however that wing uses the factory GTR wing and has a list price of $1700.
AHhhhh which GTR wing does that come from and its geniun? plus aint that too much lol or are you pulling all of our legs on that price lolz
I tend to think GTR wing's a tad little small.
I like Gracer's wing though....
PSI Parts, so if I wanted a Gracer wing by it self? Would you be able to supply?
Nice GT-R, nice kit etc... but with this is car... more show and less go... go over humps.... potholes etc will be a pain in the neck....
Here's my ride anyways... please tell me if you think it looks better with or without the wing?
http://www.skylinesaustralia.com/forums/in...howtopic=164999
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
