Ok guys,
I am after either a RB25DET COMPLETE HEAD (Cams, valves, etc) and intake manifold. (not plenum, the intake under the plenum) i will pay around the $500+ISH mark for the right stuff!
OR
RB26 complete head also including intake manifold (ex plenum) for around the $1000 ish mark.
also after these bits and peices:
- RB25DET Harmonic Balancer
- Passanger side sun visor for a R33 1994 series 1
Note: i will pay more if the head has had work done to it etc. so dont be affraid to make a offer!
https://www.sau.com.au/forums/topic/16404-rb25-rb26-engine-stuff/
Steve: Looking for a head with the intake manifold/(without plenum), just the intake manifold and complete head. I will see what i can find if nothing comes through by the end of this week i will send you a PM. :P
Cheers,
Trev.
Ive got a Rb25 Head $600 and Rb26 Head $1500not
The Rb25 Head has been ported, polished and reseated and is missing 3 coils, exhaust manifold and turbo and also top half of intake plenum and throttle body
The RB26 head is a bare head no coils, no CAS, no manifold nothing these are 3,000 complete let me know if you are keen Ive bought one too many of these and the RB25 was off my RB25/30 combo
GR8NES [email protected]
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
