Hey There Everyone!
Due to an unfortunate incident involving a seemingly blind young chick crossing the highway, my 33 has had a turn for the worse... as a result, I got another one and have sum things to sell off it. All body parts that could be painted (skirts, bars etc..) are in burgundy red and in excellent condition. All parts are of gts-t and r in good condition unless stated.. happy looking :P
Please don't hesitate to make any reasonable offer if any items seem incorrectly priced.
ENGINE ACCESSORIES
Sard 550cc side feed injectors (suit 33) – $600
Custom turbo made by ATS roughly 10,000k's ago - high flowed - larger comp & exhaust - minimal lag and no shaft play - its nice :( $990
T3/T4 XY Turbo + custom dump (rated up to 550hp) – setup to bold straight onto rb25det - $650
Standard R33 gts-t computer - $150
BOV (GFB) fully adjustable pressure/atmosphere/recirculate - $350
Apexi PFC + hand controller (allready programed by Racepace in Bayswater, Melbourne) - $1350
Bosch 044 in-tank fuel pump – good for 600hp - $250
(above setup with custom turbo was putting out 224rwkw @ 13psi as a daily driver - plenty of room for more psi - can provide dyno sheet)
BODY BITS
400R side skirts - (slightly damaged on one side, needs very minor repair - possibly no need to repaint as damage is on side covered by front wheel) - $250
400R rear bar + side pods - $500
Standard gts-t rear bar - $150
GTR side skirts - $200
GTR series 1 rear spoiler - $400
Drift spoiler - $270
Rear quarter panels - $650 each side
Doors - small dint on each door so... $350 each
Boot lid - $150
Tail light assemblies - $120 pair
Sunroof - Make an offer (don't really wanna let go of it but may..)
All parts already painted and ready to fit!
RUNNING GEAR
R33 gts-t engine - $2200
Gearbox (less than 8000km since full rebuild) - $2300
Tailshaft - $100
Diff - $900
H/D sports Clutch / 8000k's old - need to check condition - $250
INTERIOR
Dash - $700
Seats - $150 each
GTR indigo blue dash cluster - brightness and colour changeable - $1000
Complete interior available, too many parts to list - $make offer
OTHER RANDOM BITS
Brakes + master cylinder + rotors + brand new front brake pads on - $800
3½â€ cat back exhaust - $350
Lowered suspension, sits 400R front bar and skirts on 33 @ 100mm :rofl: However maintains nice ride - $500
Well thats all i can think of now, but if anyone is looking for any other things which aren't on here, let me know coz i've more than likely just forgot to put them up. If any prices seem wrong just let me know and we can work something out, fairly flexible.. haven't wrecked any skylines before. Obviously all prices need some postage put on top, but that can be worked out on a per/part or group/parts basis. my number is 0439 563 027 and my email is [email protected] - if no answer on mobile, just leave a voice msg and i'll get back to you, or sms. cheerz!
Edited by gajac1
https://www.sau.com.au/forums/topic/164085-r33-parts-and-accessories-for-sale/
interested in seats, will U ship it to Poland?
hey, your interested in my seats? I'll ship them anywhere but you have to pay the postage! if you can organise that, just deposit the money and tell me how to send them. what are you putting the seats into?
