My skyline seems to have a brake fluid leak, which seems to be located at 2 spots underneath the car on driver sides where the oil seems to out of 2 places about 10 to 20 cm apart from each other from 2 holes,
where would be the common place for an brake fluid leak?
and where would be an uncommon place for a brake fluid leak?
and how would i come on fixing the leak if the leak is right underneath my car?
:rofl::P:(
Bruno
https://www.sau.com.au/forums/topic/164092-oil-leak/
well the leak is not located like under the engine more like right under the passenger side, and like a fair few has come out like 1/4 of what was in there maybe bit more over 1 to 2 months sitting still in my garage occasionally starting the engine so battery wont die on me.
well i look at it tommorow but thinking about it could be one of those 2 things starts to make sense nows.
THanks heaps
Would you know how much master cylinder or brake booster will cost me?
Edited by BRUNSKIGTST
https://www.sau.com.au/forums/topic/164092-oil-leak/#findComment-3043511
just to check with you - are you sure its brake fluid, I am assuming that the brake fluid resovoir is low. Does your car have abs? abs is located on passenger side so it could be fluid leaking from that and running underneath the car.
yea its brake fluid my resovoir was like 1/4 left when i toped it up the other day, well its the mastercylinder leaking into the brake booster which leaking to this part of the car which travels down to the bottom of driver side of the car where is leaks from these 2 holes from the bottomw, im getting price for reconditioning my mastercylindar so dunno how much it will cost might get brake booster done as well to be safe, save money to spend on other parts. im also getting price on new one but rather get it recondition if it cheaper if it more than a new one i get a new one.
https://www.sau.com.au/forums/topic/164092-oil-leak/#findComment-3049147
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
