Hey Guys,
Anyone know if Kutsie can tune a Power FC D - Jetro in my 32 GTR ?
Anyone down here used one of these in their cars yet?
I am keen to get rid of my Airflows and hunt some more power
I don't wanna take my car to melbourne just for a tune :)
All help much appreciated
Thanks
Robert
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/
why not use AFM's? The D-Jetro isn't the best MAP sensor ECU out there (s**t to tune), if you realy want to go to a MAP sensor, i'd get an Autronic, or Haltec, and at that stage you've spent more than a PFC + bigger AFM's.
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3047170
thanks guys everyone has said the same thing thanks very much for the imput! just thought it would be the way to go as more flow less restriction and less electronics to stuff up
Anyone have any ideas how much it costs to tune when first bought, with bigger injectors and adjustable cam gears, just so i have an idea how much to budget?
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3049958
Roughly ~$150 an hour as an idea.
If you are serious about Nick tuning your car PM me.
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3053665
Well yet to order the computer will be doing it over the next two weeks after the coilovers go in,
I was under the impression the Airflow meters are going to be an ongoing problem with aftermarket turbo's and high boost levels and as everyone is aware they are not the kinda thing you wanna be replacing on a 6 monthly basis
Maybe X - Rated should shed some light on how long this kind of thing lasts on a large power basis, did you or Sav Man ever have to replace these after buying new ones and running for a whilst with a PFC?
Has anyone had a Haltec or Autronic ECU installed down here with success?
I would hate to be the first one to be bitten in the arse just by trying something new!
Have priced a Wolf V500 ($2350) err to expensive compared to what other companys are offering for lower prices
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3053732
I have had my Nismo AFM's for 2 years now, not 1 problems. one of my std AFM's died just after I got the car (due to age) that's why i went Nismo's. Our Targa car has 318rwkw, and has been raced all it's life, and it still has it's standard AFM's (and it runs a PFC), you just have to make sure your air filters are doing there job (and not over oiling them), and AFM's last for ages.
https://www.sau.com.au/forums/topic/164128-pfc-d-jetro/#findComment-3068977
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
