Hi guys,
Just added an s-afc and a HKS EVC 3 to the car, and it dyno'ed at 255hp with 200rwkw at 13psi (did 270hp at 15psi)
my mods include:
hi-flowed T03 with T04 compressor
full turbo back exhaust
s-afc
EVC 3 boost controller
stock intercooler
I'm wondering whether or not this is the power it SHOULD be making or whether it is lacking anything.
And what would be a good quartermile time for a car like this
All input will be greatly appreciated
Zak
the car is a 1995 R33 Gts-t
https://www.sau.com.au/forums/topic/16422-is-this-good-power-or-not/
hmmmm.. does look you're not pushing much more than the standard 180-200rwkw most stock turbo people can get.
everything must be running pretty hot, thats all i can say! What has your tuner told you in terms of why you aren't getting more?? I am sure the first thing he *must* have said was the i/c.. even a cheapish GTR cooler should give u large gains.
Well I've never seen the stock turbo make 200rwkw with the standard intercooler, so there's definately more power to be had, I imagine another 30rwkw would be on the cards with a FMIC.
1/4 mile times for your current setup should be mid-low 13's, with the FMIC you can certainly crack a high 12 if you can get the power to the ground, I've noticed alot of peoples times don't drop much with the increase of power but the mph do go up indicating not much traction, so in my opinion any thing over 230rwkw must have slicks to race with or your just wasting your time.
Originally posted by Nrage33
and it dyno'ed at 255hp with 200rwkw at 13psi (did 270hp at 15psi.
Not being picky (just filling in time)
255hp = 190rwkw @ 13psi
270hp = 201rwkw @ 15psi
correct ?
:bahaha:
I'd personally be U/G'ing the stock IC @ ~170rwkw.
yea i know I should be replacing the stock cooler...haven't had the funds for that kinda work yet. I've got one on hold, $1500 for cooler plus piping...good price or not? any better deals?
I don't run it at 13psi all the time, 9psi is good enough for the streets. Can't afford to go nuts around here anymore
I was told by several ppl the car could make into the high 12's if the launch is a great one.
benm u're right about the numbers...my mistake
Originally posted by BOOSTD
Mine made an extra 20+rwkw just buy changing the cooler and nothing else.
How can an i/c increase power... doesn't it just allow for longer lasting power by keeping things cool?
So by adding fmic to a line that already has exhaust and filter, will see increase in power?
FMIC with the usuall mods of more boost, exhaust, filter etc... won't yield great results without the introduction of at least an SAFC or full replacement ECU, as those mods generally see the A/F ratio run deep into the 10:1's, but once the A/F is returned to a respectable 12:1 that's when the results come.
With FMIC, exh, stock turbo my car made 168rwkw, with the SAFC tuned at 11.8:1 it made 188rwkw@12psi, only 20kw more in peak power but power was up all through the rev range and the greatest gain was at 5500rpm where it made 44kw more.
All you guys are forgetting about flow. There is power to be had if you increase flow. This is the main restriction with the stock cooler. You will make more power at the same boost level and temp with a larger better flowing core. Try testing your boost level first before your stock cooler and then after and you`ll understand. No flow-no power no matter what the temp.
Guest INASNT
My tuner has told me everything is running fine, tuned it all the way up to 18psi at one point. He's assured me that the stock cooler is fine, but has obviously recommended a front mount :P
does your tuner realise that there is around 7 or more psi pressure drop through the stock cooler? and with a bigger turbo flowing more air it would be even worse!
I'd suggest an upgrade of the cooler and the computer. I've always been of the opinion that if you change the turbo, you change the computer (and a SAFC isn't really a full computer change imo). There's a lot of power to be had in adjusting the timing I think.
2 other things, my car became a lot more powerful with just a cooler change, so I really recommend it. Also, I feel 14psi is fine as a constant setting for the street because you aren't holding it at that like you are on the track.
BOOSTD, sorry that post wasnt very clear was it.
I was just suggesting that with a stock cooler on stock turbo, it is inadvisable to wind boost past about 12psi because of the pressure drop on the stock cooler - as you pointed out. With a stock turbo on FMIC, you can only get another 2.5 psi, because after that the resistance generated by the compressor causes alot of strain on the ceramic turbine, and failure is a matter of time - so the net total boost increase (flow gain) is only a couple of psi - safely. Definately a couple of psi worth having though.
As boost pressure is measured from the plenum, the boost seen by the engine is still going to be the same with bigger cooler, it will just be cooler, denser charge. (unless you wind the boost up)
I do understand that you were pointing at the huge pressure drop on the stock cooler above 6000prm:)
the above figures do not allow for the BOOSTD 'give it 1.1bar till she blows' theory...lol
does that make more sense?
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
