  • Replies 114
Well Jess, I am planning a visit around end of May - early June to celebrate my Birthday... perhaps I could make it the weekend of teh SnS instead and come help out my second club :blink: :sorcerer: That is if you still need people... :)
Well Jess, I am planning a visit around end of May - early June to celebrate my Birthday... perhaps I could make it the weekend of teh SnS instead and come help out my second club :D :sorcerer: That is if you still need people... :D
Anna!!! That would be awesome! :blink:
Would love your help :)
so where or how can i get skyline shirts for us girls?
You need to check out the Merchandise thread and see what kind of shirt you would like and size and then PM Goldzilla and tell him what you would like and deposit the cash into the SAU bank account :)
  • 3 weeks later...
I might be in for helping maybe with the promo thing... have to come up from the South Coast but would be good to meet some new people. I might have another friend interested in helping too.
Can you PM me some details about what we would be doing etc??
