Guest INASNT
Originally posted by RON-15H
just wondering i have just ordered a trust dual piller guage holder and i intend to use autometer guages are saying that they wont fit?
cause the jap size is 60mm
and the autometer size is 2.25" which is the same???
they dont mate up 100%, u will have to trim the gauge holder a bit.
Originally posted by INASNT
yes, ask meggala, 1 of those boost gauges was the cause of his blown engine
I believe you and your opinion on these forums means a lot i think and you know your stuff but are you basing your writing off an entire range on just one instance or is there more proof that they are crap.
I just want to know as i though that splitfire and autometer were in the same league and i havn't heard anything wrong with autometer.
i got my one form rampage in newcastle cost me $180 the spiltfire gauges u just haw to cut the top out very finely just a little bit at a time ever slowly till u get a it to fit to mch and it looks shit house u c the back ov the gauge
so yes u can fit the big spiltfire gauges in to the piler mounts and looks good
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
