Friday arvo i left sunny Adelaide for a road trip with a difference.
On the net i found a complete rolling 06 model yzf450 quad in Newcastle, and a 06 model ZX10R engine in Sydney.
So i figured why not.
any way 36 hous later and im back home with my new toy.
i drank two beers while looking at where to cut, and what would fit where, then grabbed the nine inch grinder and went for it. The pics below the motor is just sitting there, as i will have to drop it another 30mm and also move it 20mm left.
but its in and wont be to hard to make work.
any comments at this early stage?
Cheers
Darren
Edited by dangerman4
https://www.sau.com.au/forums/topic/164659-my-next-toy-170hp-quad/
  • 2 months later...
What other mod's did you have to do to get her going, still using same ratio and brakes?
stock gearing is 15 / 40
and im running 14 / 38 but with the smaller back tyres it gives me a top speed of around 230kmph at 13k rpm
here's a few picks
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
