Item: Q45 Air Flow Meter
Item Condition: Pretty Bloody Good
Reason for Selling: Impulse buy. really required a Z32 AFM
Price and Payment Conditions: $200 ono
Extra Info: Q45 AFM in good nick with plug.
Item: Snap On Ratchet Screw Driver
Item Condition: Brand Spanking New/Perfect
Reason for Selling: Came as an extra in screwdriver set i bought and i already have 1
Price and Payment Conditions: $100 firm
Extra Info: its soft grip black and red colour. little end bit comes off which can be used as a stubby and you can store xtra bits in there when not needed. comes with 1 blade and 1 phillips head tips. its good, its snap on. its brand new. you want it. i dont. come and buy it
Contact Details: Ross - 0421 869 037
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
