Hi Everyone.
Some of you may remember this r32. It was for sale a few months ago. I imported the car my self, and unfortunatly it failed compliance due to the 'jacking points' being pushed in more then 20mm. This could have been caused from a number of things, my guess is the car forlifts in japan. The workshop i was using has been shut down, and now im stuck with a car that cannot be 'legally' complied registered.
Everything else about the car is perfect. It drives excellently, it has the power that it should have and it is clean, inside and out.
It is totally ridiculas, but im not going to get into that here because i could go on complaining and winging for ever. Yes i've lost alot of money, and yes i've thought about wrecking it. All because the jacking points were pushed in 2mm more then what is allowed. But i've moved on from cars now and i'm just going to cut my losses and sell it as is.
Basically, the car is is in very good condition. Hard to believe for a car that got rejected hey? The motor is in perfect (82,000kms on clock) and the gearbox is tight and the clutch is bouncy and fresh. The car was resprayed Gold in japan. It is very tidy inside and out, and looks great as you can see from the pics.
All the compliance work has been carried out on this car (full service etc, even though it isn't complied) and i've driven this car about 500kms, just on a dealer plate and had no problems what so ever.
Its a Gold 1990, r32 Gts-t Type M
Manual
Turbo
Aftermarket suspension
The steering wheel was returned to stock as well as the gearknob.
The exhaust, podfilter, gage and turbo timer have been removed, and i will be removing the cd player and radio.
I'm after $5500
Any questions etc, just post, or email at [email protected] or call on 0422373164
Regards
Mondial
post-2280-1176902976.jpg post-2280-1176903000.jpg post-2280-1176903011.jpg post-2280-1176903024.jpgpost-2280-1176903047.jpg post-2280-1176903061.jpg post-2280-1176903076.jpg post-2280-1176903086.jpgpost-2280-1176903097.jpg post-2280-1176903155.jpg post-2280-1176903165.jpg post-2280-1176903175.jpgpost-2280-1176903184.jpg post-2280-1176903203.jpg post-2280-1176903213.jpg post-2280-1176903223.jpgpost-2280-1176903232.jpg
Edited by Mondial
https://www.sau.com.au/forums/topic/165155-sold/
mate the easiest way would be to part it out.
r32's are getting old so a lot of things would need replacing on them.
although it would be a shame to see such a nice car being wrecked, but whatyado
good luck
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3061491
My worst nightmare...compliance...sorry to hear about your bad luck...
Where bouts u located? (if its there i must be blind...)
Yes this car can be used for whatever you want, just not on the road.
You only get one chance at compliance, if it doesnt pass, it doesnt pass.
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3061716
thats so unfair. Surely you couldn't have the points super reinforced or something, then go back to a different engineer, it would probably be stronger than it ever was, and worthy of ADR's.. I would think.
Also can you claim anything throught the shipping insurance, or hold the car yard responsible perhaps?
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3079349
i hope this rule isnt the same for chaasis rails my r33 is on the way from nz both front ones are pushed up on the insides cose some idiot used a trolley jack on it for its wof(rwc there)to jack it up...oh dddddaaaammmmmm.......while im here anyone know if my car can be complainced there using my tein adjustable suspenion??its a personal import..your rules are all over the place and very silly someone needs to clean it up sorry for hi jacking ya thread...
Edited by mr rb25 r33
https://www.sau.com.au/forums/topic/165155-sold/#findComment-3081993
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
