i must be the only 1 but i dont like it , that interior is awful
really? show us a pic of your gtr's interior. let me guess, boring grey? just kidding mate. >_<
i really like it. luxurious leather, eyecatching color, perfect fit and finish from the looks of it. basicly what a supercar should have.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/page/2/#findComment-3084110
  • 4 weeks later...
A quick update:
CTR3's new developed body concept showing the latest version of the famous RUF IRC (Integrated Roll Cage).
If the car is based on anything, it's the Porsche 997 Turbo.
Behind the seats, the car is 100% Ruf.
The seats are Ruf's own design and both comfortable and sporty.
Interior is a mixture of 997 Turbo and Ruf.
Front is based on 997 Turbo, but with many Ruf specials.
The roof is 12 cm lower and the windscreen is special.
The gearbox can handle 1200 Nm.
It's like a 997 Turbo, but with a very powerful mid-engine.
The R50 will be 100% Ruf.
https://www.sau.com.au/forums/topic/165168-ruf-ctr3/page/2/#findComment-3139359
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
