I have a HKS dual solenoid boost controller. with everything u need to connect it up.
These things hold boost the best as my brother has one on his skyline as well, i gotta sell mine coz i need the cash to pay for some bills i got so looking for quick sale of $250 im in Melbourne western suburbs about 5 mins from calder park raceway. I will put up pics later tonight
Ill take it for $240 + Shipping. Can you please send me some pics?
