Hey,
I've recently found that my car is detonating (sounds like someones got a handful of marbles and shaking it in there hands) at 6000RPM - Usually only happens when I put the throttle flat if I ease it it won't happen.
It sounds like it is coming from the rear of the car.
The car is a 1993 Nissan Skyline R33 GTS-T, current mods are as follows:
- K & N Pod Filter
- Custom Pod Enclosure
- Cold Air Intake
- Forged Pistons
- Strengthen Conrods
- Blueprinted
- Balanced
- Port Polished
- Metal Head gasket
- Spitfire Coils
- High Performance Timing Belt
- High Performance Spark Plugs
- Gready Turbo Timer
Everything else is stock, including the ECU.
Any ideas of what the problem could be? Thanks.
https://www.sau.com.au/forums/topic/165607-detonating-at-6000rpm/
Check your timing. Try retard your timing 5 degree to see if that still happen. Might be your fuel (use 98 octane)? What boost are you running? Maybe your compression ratio not right. There are heaps of possibility.
I'm running 98 Octane at the moment, have run 100 Octane (V Power Racing) never anything below 98 Octane however. I'm running stock boost at the moment also.
if you know it is detonating then you need to look at engine management.
aftermarket ECU and tuning is the best answer.
Yeah, thats what I need to do. I've got a 3" Cat-Back Exhaust, Bleed Valve and SAFC2 sitting here ready to get installed and I should be buying one of the Front Mount Intercooler Kits from one of the Forum sponsors. Then get it all tuned, and dynoed - I think thats my best bet.
Might even chase after market Fuel Pump.
Aftermarket fuel pump is a good idea mate. That could even be causing it to detonate if the standard pump is failing to supply at 6grand wot +, when did you change your spark plugs last and to what gap?
Spark plugs are fairly new, I think it's 0.8 I'm not 100% sure but it's the NGK Platinum ones.
Check your timing.
Will do :santa:
Thanks for everyones help.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
