all SOLD
post-34389-1180871771_thumb.jpgHi all, up for sale are some awesome looking lanyards, I have [/b], 1 Nismo($13), black (they have a clip in piece at the bottom to detach ure keys etc), this is the last one so get in fast if you want it!! I am located in Tas, but can chuck em in the post for you (at buyers cost---$3.00), cheers
Edited by madaz R33
https://www.sau.com.au/forums/topic/166075-sold/
i'll take the subie one delivered to brisbane thanks.
No probs, i will pm u account details and do a dry run at the post office on my lunch break, whats ure post code & send me ure address in a pm, cheers Damo
https://www.sau.com.au/forums/topic/166075-sold/#findComment-3075122
$10 for the nismo??
I knew this would happen lol, because i didnt state "firm" someone would try and beat me down!, I am willing to sell it for $12(no less) :laughing-smiley-014: not $10, cheers
https://www.sau.com.au/forums/topic/166075-sold/#findComment-3077286
ill grab the nismo then for 12
will have to get back to you on the nismo lanyard, may be sold, will inform in thread if not, GTIR still up for grabs, will sell for $5 + postage
Edited by madaz R33
https://www.sau.com.au/forums/topic/166075-sold/#findComment-3090685
nismo lanyard still for sale, as is GTIR lanyard
https://www.sau.com.au/forums/topic/166075-sold/#findComment-3105712
Your attachments dont work man
Hmmm.... thats strange! they were working last time i checked, but as u say they are not now, i will edit and re insert them soon as i get a chance, thanks man
https://www.sau.com.au/forums/topic/166075-sold/#findComment-3147494
Attachment fixed, last nismo lanyard still up for grabs
https://www.sau.com.au/forums/topic/166075-sold/#findComment-3158703
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
