Here at planet potato if we can't see an A/R number we look inside the mouth of the turbine housings mounting flange .
HKS's T04Z turbine housings have two inlets even though they are not a divided or twin scroll housing . From my diagrams these housings should have the number on the right hand wall of the right hand passage .
Cheers .
https://www.sau.com.au/forums/topic/166208-hks-t04z/#findComment-3080117
Cheers .
so the same as the compressor housings. interesting
https://www.sau.com.au/forums/topic/166208-hks-t04z/#findComment-3080122
i had a look inside n theres nothing there ...
bman, i didnt get the housing, i spoke to gcg n they told me $450 with everything.. but if i do decide to get the 1.0 ill get it off u.
might have a change of plan as my brother wants to buy my car which means i might jus have it finished and look to import a mental one with nothing to spend, theres a few 9sec ones floating around...
https://www.sau.com.au/forums/topic/166208-hks-t04z/#findComment-3080231
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
