  • Replies 53
Posted Images
Just picked up my R33 S2 on the weekend from a long distance purchase and the seller did not mention this item was in the car at all, I was all for ripping it out thinking it was only for people who could not change gears at the right time, untill I read this thread :whistling:
What a cool device.....
Unfortunately for me it did not come with any destructions, can anyone point me to a Website that has a downloadable User manual? If not, can anyone upload a scanned copy of there's? That would be appreciated, or even a basic instruction of use? I'd really like to get the launch control sussed.
Cheers
Its pretty simple to use dude. You have the two settings, REV1 and REV2. REV1 is your normal rev limiter so you set that to what you want it to be and leave it (obviously this needs to be a few hundred RPM less than your factory limiter). As its a pretty basic design you will need to use trial and error to find the correct adjustment for the setting. REV2 is your launch rev limiter (ie only active when your handbrake is up, assuming they connected the switch) so you set this to a nice sweet torquey spot in the rev range.
Gain is just the frequency of the cuts...no idea which way is which but one will be long loud bangs and the other short sweet pops.
ps, Im not 100% if I got the two settings the right way away, ie REV1 could be launch limiter and REV2 could be normal...you will figure it out.
I'm currently getting one of these fitted in my car and of course no instruction so i've done a bit of research for the r33 rb25
i'm about 95% sure i've got it figured
okay here goes:
ECU ____________________ Bee*R
pin 41(green/black) - yellow wire cas 120 signal
pin 42(green/yellow) - green wire cas 1 signal
pin 49(white) - red wire 12v
pin 50(black) - black wire (earth)
the white wire is for the second limiter and is commonly put to the hand brake
Red wire: 12V+
Black wire: Earth
Yellow wire: RPM Signal
Green wire: Ignition signal
now I've concluded to this from scrolling through the several japanese instructions and comparing it back to the r33 rb25 workshop
now if i've got anything wrong please let me know
cheers
Edited by Darkon
I'll be hooking up a switch to the clutch pedal to allow launch control and flat shift ability.
IE. When you hit the clutch, the Rev-Limiter drops spark to attempt to go back to say 4500rpm......
Keep right foot on loud pedal.
Change gear, drop clutch and bang, off you go again.
I've driven an R34 GTR with this set up through the Motec and the changes are so smooth you wouldn't believe it. and Lightening fast.
Has anybody actually had theirs fitted and is it working?
I had a look at the little dials, and it has numbers around the base, and the dial keeps clicking around.
How accurate can you get the rev limit point?
How many RPM between each click..... ?
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
