  • Replies 153
Guest INASNT
Originally posted by dabigbolf
inasnt whered u get yours how much?  and is having it venting to atmosphere better or worse.  as i see yours dont have the filter on top.  still looks neat though.
i actually bought it off some1 on here!
if u want to vent it to atmosphere then all u gotta do is drill a hole in the top and insert a filter on top.
hehe,
i'd think not.
from what i have gathered it just makes the air go out easier.
some just have a little hole, but the venting one, vents more.
i think heard someone say they lost a litre of oil due to one, on track day on the vl turbo forums.
but that would have been fullstick non stop for 5 or 10 minutes of laps.
The difference between a catch can, and an oil/air seperator is that a catch can simply collects the crankcase fumes, grabs the oil out of it, and lets the air go. It would theoretically fill up with oil eventually and need to be emptied. An oil/air seperator is the same thing, except that it has an oil drain back into the sump, thus reducing the maintainance level, and ensuring that you don't run low on oil in situation where the crankcase may be breathing heavily ie. track use.
For both devices, the vented air can be routed back into the intake (where it originally went anyway) as it should now be free of oil, and this will eliminate any possible legal issues with emissions etc. At minimum a filter should be fitted because a) the catch can/seperator won't be 100% efficient, so there will still be *some* oil vapour in the air, and B) the crankcase can breathe both ways, and you don't want to be drawing unfiltered air into the crankcase.
Hope that clears it up a bit.
Belly_up - thanks for distinguishing the difference between a catch can and an oil/air seperator. I've been looking into buying one & I didnt think that there was a difference - now I know. I guess the oil/air separator would be more 'acceptable' to EPA as it is plumbed back?
Either of them can have the *air* outlet plumbed back, and thats what the EPA would be worried about.
The advantage of the oil / air seperator is that you keep your oil in the sump rather than collecting it in the catch can. As i said above, it's really only going to be a issue for prolonged high RPM use, not so much on the street.
And when shopping, the two names are used interchangeably by most people (and rightly so, because a "catch can" is acting as an oil/air seperator), so check for whether the particular item has an oil drain fitting, to determine whether it is what you want or not.
This is from the Autospeed article "Pots and Cans... Step-by-step fabrication of swirl pots and catch cans/oil-air separators..."
ASE offers two different products to prevent blow-by oil entering your engine's air intake - a catch can and an oil-air separator. What's the difference, you ask? Well, a catch can receives blow-by oil and allows fumes to vent to atmosphere after being filtered. On the other hand, an oil-air separator internally filters the blow-by oil and allows only clean air to enter the car's induction system. This is the favoured approach from an emissions and legality perspective, but it doesn't look as siik when you pop the bonnet
Originally posted by DennisRB30
If you get rid of the PCV system your engine will build up harmfull acidic gases which contaminate the oil reducing engine life.
I just got rid of my PCV and vented it straight to the Atmosphere. Is this bad? or is it only bad when you block it of completely. I'm finding alot of oil and shite in the intake. Never really known about the PCV, lol.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
