illusiVe Posted May 5, 2007 Share Posted May 5, 2007 Just installed monday.. anyway heard this rattle/scraping noise on the way home from the back of the car, thinking maybe the top bolts were bit loose or something for the coilover, took the wheel off and saw this lovely sight: The 1st pic is of the coilover with a nice flat spot (from the wheel) The 2nd pic is of the wheel with this nice shiny line going alll the way around. Anyway running 255's on the rear, had no problems with the factory shocks + 2" lowered king springs. who knows how to fix before my new coils are stripped (...besides getting new rims with different offsets) thanks in advance! - right section this time! Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/ Share on other sites More sharing options...
BHDave Posted May 6, 2007 Share Posted May 6, 2007 How low is it now? Id suggest an adjustable upper arm or bushes to correct the usual rear camber issue when the car is lowered and bring camber back into the <1 degree range. Then look at a 2mm slip on spacer if that doesn't fix it Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3101081 Share on other sites More sharing options...
illusiVe Posted May 6, 2007 Author Share Posted May 6, 2007 thanks! yer i was thinking something like that today.. u know where i can get a slip spacer? i was thinking washers lol.. car is 970mm from nismo rear bar to ground. i'd plan to raise it only a little, anyway theres going to be more camber shortly hehe yay for drift Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3101095 Share on other sites More sharing options...
n15m0 Posted May 6, 2007 Share Posted May 6, 2007 thanks! yer i was thinking something like that today.. u know where i can get a slip spacer? i was thinking washers lol..car is 970mm from nismo rear bar to ground. i'd plan to raise it only a little, anyway theres going to be more camber shortly hehe yay for drift 970mm??!!! Firstly, What car, what width and offset wheels are u running? Spacers will probably fix ur coil rubbing problem but unless we know what width and offset ur running, you might end up rubbing the guards after fitting spacers?? Might have to get a new wheel in the end.. Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3101105 Share on other sites More sharing options...
Ronin 09 Posted May 6, 2007 Share Posted May 6, 2007 hey mate measure the centre of the wheel to the guard Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3101571 Share on other sites More sharing options...
illusiVe Posted May 6, 2007 Author Share Posted May 6, 2007 problem fixed.. washers = 2mm = fixed.. until i get a proper spacer. Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3101921 Share on other sites More sharing options...
n15m0 Posted May 6, 2007 Share Posted May 6, 2007 problem fixed.. washers = 2mm = fixed.. until i get a proper spacer. Dangerous and illegal Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3101932 Share on other sites More sharing options...
shnaped_second Posted May 6, 2007 Share Posted May 6, 2007 car is 970mm from nismo rear bar to ground. i'd plan to raise it only a little, anyway theres going to be more camber shortly hehe yay for drift problem fixed.. washers = 2mm = fixed.. until i get a proper spacer. LMFAO.... :laughing-smiley-014: Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3102782 Share on other sites More sharing options...
mid life crisis Posted May 6, 2007 Share Posted May 6, 2007 (edited) his next topic will be how to fix broken wheel studs after loosing rear wheels washes= stupid and dangerous Edited May 6, 2007 by mid life crisis Link to comment https://www.sau.com.au/forums/topic/167599-coilovers-are-rubbing-against-my-wheel-insides-ouchies-over-bumps/#findComment-3102819 Share on other sites More sharing options...
