  • Replies 120
i think u should make a cruise or u can come pick me up cruise to a club check out the talent maybe pick up then cruise to another club check out talent and do that. there u go a cruise all planned out we shall start at 9 pm i think then when u get bored of me that will be the end of the cruise :(
what do u think :wave:
nah it was to stop long enought to see the talent if good work the magic then cruise to next club not go in that would take to long to get in haha :P
so i think that idea is good then when u get bored we find someone to race hahaha so u picking me up on friday and u can put this sign on the car pointing to me hahaha :)
i call shot gun and i call shot gun for the im stupid hat :D
hahaha this sounds fun so are we actually going to do it R Dirty 3 are u coming to Jess
Probably not LOL
Have a mate from out of perth coming down. He is a jap import driver also. Was going to try and show him the perth scene, but as there are no cruises on, i guess not.
hahahaha my bad apoliges to Jen but i dont think i got u mixed up but if i did my bad any way RDirty3 he will be seeing the city life but instead of a lot of cars he will be seeing a lot of girls hahahah okay another day :D
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
