Item: 1999 SUBARU LIBERTY 3GEN MY00 RX
Website:
Item Condition: Good
Reason for Selling: want something else, any straight swaps or swap and cash my way considered
Price and Payment Conditions: $12500 negotiable, all offers/swaps considered
*** Now with 6 months rego and new front tyres
Extra Info: Besides the below features this car has a custom exhaust and has had the major service done twice both including the timing belt due to the mechanics error.
Mostly highway kms as i work an hour away from work.
16In Alloy Wheels
6 Speaker Stereo
Abs (Antilock Brakes)
Adjustable Steering Col. - Tilt Only
Air Cond. - Climate Control
Airbags - Driver & Passenger (Dual)
Body Colour - Bumpers
Body Colour - Door Handles
Body Colour - Exterior Mirrors Partial
Body Kit - Lower (Skirts, F & R Aprons)
Body Side Mouldings
Cd Player
Central Locking - Remote/Keyless
Cruise Control
Disc Brakes Front Ventilated
Disc Brakes Rear Solid
Engine Immobiliser
Fog Lamps - Front
Footrest - Drivers
Headrests - Adjustable 1St Row (Front)
Headrests - Adjustable 2Nd Row X3
• Hill Holder
• Independent Front Suspension
• Independent Rear Suspension
• Intermittent Wipers - Variable
• Leather Gear Knob
• Leather Hand Brake Lever
• Leather Steering Wheel
• Map/Reading Lamps - For 1St Row
• Power Door Mirrors
• Power Steering
• Power Windows - Front & Rear
• Remote Fuel Lid Release
• Seatback Pockets - 1St Row (Front) Seats
• Seatbelts - Lap/Sash For 5 Seats
• Seats - 2Nd Row Split Fold
• Spoiler - Rear
• Sunvisor - Vanity Mirror For Passenger
• Tacho
• Velour Trim
• Woodgrain - Centre Console
• Woodgrain - Dash Board
Pictures:
Contact Details: [email protected] or 0401187380 or PM me
Edited by krissy83
https://www.sau.com.au/forums/topic/168148-sold-please-delete/
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
