hi gang,
up for sale is the grill that came off my car when i bought it. its an aftermarket 400R carmate style me thinks painted in factory burgandy colour. i got myself a GTR grill so no longer need this. comes with mesh and brackets to bolt on to the factory series 1 (maybe series 2) nose.
PICS:
http://www.carmate.com/product_details.php...G&p_id=8846
asking around $80 or the nearest offer. would prefer to get it out of the way this weekend. if you want a new grill to replace those hiddious series 1 factory grills and ur car is red / burgandy then ur laughing.
located in the southern shire area also the western sydney area.
PM me for more details.
Cheers! :(
https://www.sau.com.au/forums/topic/168218-fs-400r-front-grill/
  • 3 weeks later...
