Just thought i'd post up a picture of my 1984 300c. I'm pretty happy with it so far (had it for 8 months) - and i've only seen 2 -3 others around Melbourne during that time. It runs the vg30e motor with a 4 speed auto. Gets up to 100 around the 10 sec mark, and handles really well too.
Might do some sort of engine conversion later on, or just lower it slightly and give it a fresh paint job.
https://www.sau.com.au/forums/topic/168552-my-300c/
Hi there,
Nice looking car. Seems to have been looked after very well. I'm sure I'll see you around the traps. Be sure to wave and say hi!
yeah i bought it of a dealer my friend knew who said it was traded in by some old bloke, so i got a pretty good price as they probably took it off his hands for next to nothing :rofl:
https://www.sau.com.au/forums/topic/168552-my-300c/#findComment-3115634
  • 3 weeks later...
  • 2 months later...
  • 5 weeks later...
Well the car isnt at my house at the moment, partly because there is no space and partly to prevent me driving it :wave: but maybe this summer come around and we'll compare
I'm actually trying to source a motor for it at the moment, as the timing belt pulley bearing broke and i got a new pulley and belt put on it but its had a miss in it since- im thinking maybe a bent valve somewhere..
i got a quote at 660 but that particular wreckers didnt have any in stock. i might ring the one in centre road, see how many kms are on the one u mentioned..
https://www.sau.com.au/forums/topic/168552-my-300c/#findComment-3363510
  • 1 month later...
I cant fit spacers, otherwise it starts rubbing the inner guard in the rear. It's pretty tight in there due to it's height. The fronts I'm running 5mm spacers to clear the struts. If I go any bigger, I wont be able to steer the bloody thing!
https://www.sau.com.au/forums/topic/168552-my-300c/#findComment-3500936
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
