Misc Parts From R32 Half Cut And Odd Pieces... Pm Me What U Need
dont suppose you have an rb20det ecu by any chance, do you?
*fingers crossed*
hey mate sorry i dont. its on the S13.. at the moment.. fine me a PFC and ill sell it.
Pm sent
replied. all pms replied.
Bonnet sold
dash is off, and will seperate airvents... :mrt:
  • Replies 57
  • 1 month later...
Hey mark will see you tommorrow but was wondering if you have the vent that sits in the very top iof the dash for the demister on the R32 gtst.
i really need one i snapped mine when i painted my dash.
cheers kingy
  • 4 weeks later...
how much do u want for the dash dude? is it in good condition. i dont want any air vents or anything just the dash pad
make an offer.. itsin very good condition.. air vents are seperated. send me a PM
oi DELETE SOME PM'S your inbox is FULL
yo. sorry it fills every second week.. pretty small limit lol.
  • 4 weeks later...
still have all the under dash aircon gear?
hi richard
sorry mate goneski to adam a while back :)
anything else u need. got std a/c climate control unit the electronic one
hi richard
what you asking for it? cause i get error -26 on my climate control now, but its like my 3rd one, could be buggered.
hence why i thought it was the control box under the dash?
  • 3 weeks later...
any chance of helping us out again?
After the front crash bar off the R32 halfcut, if it is undamaged?
aircon compressor, still got it?
if so has it been sealed up as to not dry it out?
how much?
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
