Heya my battery is on the way out and i'm wondering where to get a new one? The NRMA didn't have one the right size and told me to go back to nissan to find one. Anyone know where to get a trusty new one in Sydney preferrebly around the north shore area at a good price? thanks
No repco does not sell it either does super cheap auto barn etc... Bob jane sells them .. they sell them at one store in sydney tho ..
Edge cliff :|
So im pretty sure the guy I got my car from Joel (aussiecarcomplience.com.au, exciteautos.com.au) sells them .. let him know Nathaniel put you into contact with him and he'll sort you out .. last time i was there he had them good bloke so should look after you :domokun:
R34 batteries are shit hard to get.. I eventually had to "shape" my battery clamps .. took alot of "molding" but we got them on :P
I doubt that r34 batteries are hard to get at all.
with r33s, you need sealed batteries sicne it's in the boot. Even then, there are lots of varieties of sealed batteries, and there are many that fit.
With the last r34 that we changed the battery on, it just has a battery under the bonnet. Just whack any thing under there with the right terminal size. It's no biggy.
As opposed to r33s that requires sealed ones, with an r34, how much you want to spend is up to you. From $50-500
thanks for the fast repies! The guy from the NRMA had a ute full of batteries but none would fit without modifying the car because apparently the R34 uses a pretty big batt but with the narrow terminals or posts from a smaller battery?
Edited by R34 Rampage
Jap battery posts are smaller (thinner) than the ones we use in Australia (SAE). You can either modify the standard terminals (eg with a screwdriver, prise them open) to fit the SAE posts. Alternative is to cut off the old ones, and fit new terminals.
Battery sizes shouldn't be an issue. You can pick up plenty of equivalent sized batteries around here. Don't need to be as small as the stock battery either.
Spot on the money razor. Most jap cars (not the aussie delivered ones like camrys) used the small terminals. Hop down to battery world, and most batteries come in big or small terminal.
We're not in the ice age anymore where bogan terminal batts are the only thing on sale. NRMA usually have big terminal ones, but i'm suprised they dind't at least have some small terminal ones. Maybe they did, but they weren't big enough interms of cca.
At b82rz world, they have massive cca in small terminals. Look for amaron batteries - silver calcium low maintenance (maint free but not full sealed - no good for r33 in the boot) but they're a great battery.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
