Audio setup (WOW! amy very own thread!:D)
Guest veesixtyfour
Hey Guys,
Im looking at a setup for the '95 R33 GTST im getting
I listen to alot of r'n'b and dance/trance/hinrg mainly
I was thinking something along the lines of:
pair of 12" Subs
pair of 6x9's in the back shelf
  • 2 x 12" subs (maybe 10" if respose is better not how the rnb tunes will go)
  • 2 x 6x9's
  • 6" or 8" Splits in the door with tweet's
  • NO idea what kinda AMP(s) to run...
Basically im looking at Infinity, US Audio or JVC or a combination of all of the above (as i can get these really cheap :lol:) what are they like?
Advice would be great as im not a brain when it comes to car audio.. :( sometime in the future ill look at getting a headunit with a screen built in and prolly put my PS2 in there :) but thats a while yet... ive got a pioneer headunit from about 3 years back was about $799 RRP never been used :)
Thanks with any help guys
https://www.sau.com.au/forums/topic/1700-audio-setup-wow-amy-very-own-threadd/
if you can get anything cheap go for it!!
el kamelon jvc decks are awesome ****, us audio is decent for power amps and infinity, well, theyre nice...try to get infinity amps instead of us audio, they would be tre cool
if you have subs you wont need 6x9s
check putting some splits in the rear cabin, or just some midbass, or leave the stockies
Tell me a budget (even if it's long-term)
And, how much SQ/SPL you want your system to have
ie: 60/40 SQ/SPL etc
What does that mean? SQ = Sound Quality, SPL = Sound Pressure Level (How loud it is)
With SPL comes less sound quality usually. 60/40 is a good comprimise usually.
As i said, tell me the above figures (Budget and SQ/SPL) and i'll reccomend you a couple of set-ups.
US Audio, Infinity and JVC are good brands, but they're not the best. So i'll reccomend you a few different systems once i get figures. (ie: one using mainly the brands you can get cheap, one using a bit of them brands, and another not using them brands)
Ryan
    • Actually, if having and keeping the stock ECU is the plan, the correct answer is to put Nistune into the ECU and improve the situation, not just look at it.
    • Wrong side of sydney for me coming from Goulburn, but you should head along, all ages of Skylines will be very welcome
    • Yeah so physically that port is consult not OBD2, but also be aware that "JODB" is not really a thing - it came in around 2000(ish) but is not a standard like ODB is, each manufacturer had differences. If you are looking at ECU only and have a standard ECU, go with Datascan as Turbo Tapin said. Per another recent discussion here thought that won't do other systems like in a modern car, for example bleeding ABS
    • They're not rebuilt Racepace items. They were mint. From memory the were ex display stock that I bought off yahoo and he ran....from memory he barely used the REs when he replaced them with a set of Tein RS If have been stored correctly and not leaked fluid then they will be mint   As an observation the Racebuilt rebuilt Tein RA/RE/RS were a better street/club/track package. Really nice on the street and did good numbers at the track.  I think the factory Teins wont match the Racepace valving on the street but would be in the same window of performance on the track... albeit firmer
    • The one time that Clippy is actually useful!
