i've popped a boot before... what does that mean? :cheers:
HAHAHAHHA ur crazy
I run 3 fuses to avoid blowing it all .. and also to get the amps to power individually.. :dry: POWER!
I popped one a current got far enough to take out and cut the second one .. dunno how that works tho :D
Wheres ur boot install tempory my ass shoooooooooo me
HAHAHAHHA ur crazy
I popped one a current got far enough to take out and cut the second one .. dunno how that works tho :cheers:
well you cant really run a fuse on a boot :D
and i run less amps then you it seems... yay for f**kin powerful monoblocks!
do you run three independant fuses, or 3 on the same line?
temporary as in... no...
its an old box i had lieing around, chucked it in the boot, tied it down... for the longest time i have been trying to design a decent way to get 2 very powerful 12 inch subs in there, in a duel slot ported box that still has the required literage, and so i can still get to the battery...
any designs i came up with just weren't up to scratch...
so 2 12's it is... and probably sealed boxes too...
lol crap me dead from the sounds of it thats going to be big .. sealed boxes .. Ill help ya out if you need it .. I can use a drill and wreck stuff really well.. trust me ..
Reinforce the boot hey :dry:
I run 0gauge with a fuse in it and then split into 4's to run each amp .. seems to work well :D
Im going to run two 10" in the boot too and rice it up with some nos bottles woot
Oh and I run a 2000rms mono :cheers: and v series to power the split sensation that tingles my passengers ears
Edited by DECIM8
Reinforce the boot hey ;)
could always use another pset of hands :D
and yeah, but how the hell do you go about doing that exactly?
lol, nos bottles :dry: cut out the bottoms and put speakers in there :D
3kw... does that make me the winrar? :domokun:
I just use it to blow skirts off the gurls and make the old people look young again .. Boom boom f**kers... I never turn it up full blast id lose my hearing .. not to mention blow my winscreen out :@
3kws .. wow thats some nice shit but whats your subs run at :D But im the winnnn na na :P RICE SETUP RULES :@
Ive got the weekend off im going to tackle my box this weekend I reakon .. How fun is it trying to get a big mdf peice in a R34 .. NOT VERY :@
And running dual amps on different power lines is easy .. U just buy a spliter it it a divider which seperates the lines with two fuses in each line then u run a smaller guage out of it to each amp .. protects the amps and also gives them there own power supply .. they suck what they need..
I need to install a cap any idea how to do that .. suppose I should buy one first :|
Edited by DECIM8
Most of the system was in my old line except for the audison amp, and the headunit. The earth wire coming from the headunit is simply has a connector on the end of it which goes under the tightened screw of the side brackets of the headunit.
yeah i still do all that :P but im not normally IN the car when its up that loud :(
the subs will be rated at 2.5kw... ive had this planned for a while, i just finally have enough money for it :D its gunna be crazy...
im gunna put my car in the shop for a week, starting monday night... got a lot of stuff to do before Show N Shine :D which you had better be entering!
yeah i know, at the moment, i have had to use 2 distrubution blocks for power coming OUT of the amp to the subs :)
capacitor is easy as... youll figure it out in about 10 seconds :P
I dont think you understand the idea of show and shine... its mostly just to chill with mates who have the same car, learn a thing or two and such...
this isn't auto salon man... im entering mine, and its got piss all... hell, people are entering completely stock cars, some worse then that, and i even know a few who are entering with drift damage...
we actually have a chance to get the most number of skylines ever together in one place... it would be a world record... we can do it :D and we probably will...
oh, and the president of the club himself will be keying any skylines parked in the car park... even more incentive to enter...
seriously, you own a 34, so by default, your car is better then mine already :P i HIGHLY recomend you enter, and that you tell everyone else you know with a skyline... its local, and its $10... its gunna be a great day :)
and yeah, the cap is seriously power in, power out, and ground... thats it... it just stores power before going to the amp...
where you put the fuse is the tricky part :D
but yeah, a guy like you will figure it out in 10 seconds...
a guy like me... 5 :D
yeah screw rims... i was gunna see if i could borrow some from a store, but i couldn't be arsed :(
oh yeah, the guys from ignition are gunna be there filming... and so will HPI... so if you wanna get on a DVD or two, i suggest you come :)
its gunna be one hell of a day! :P
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
