I have an RB25DET, mods as listed below:
Full turbo back exaust 3inch - 3.25inch cat back with magnaflow cat (650cfm)
Walbro fuel pump (yet to do voltage mod).
Garrett GT30R Hybrid turbo kit, in a hiflowed rb25 turbo housing (toit like a toiger).
FMIC, turbo 2 afm metal pipe, POD, CAI (not enclosed).
Stock injectors, stock afm...
Is an SAFC Suitable for tuning my car at this point for me to reach a good safe solid 200-205kw?
I'm also looking to regain a bit of economy, as atm im only getting around 260-280km per tank. on 98ron bp ultimate, never used any other fuel or will ever use any other.
Please tell me if an SAFC will be suitable for this. I know I am limited by the AFM and injectors but i want to get the MOST out of the stock stuff for when I get better stuff or a suitable engine management system becomes available to me.
Thanks,
Paul.
https://www.sau.com.au/forums/topic/170537-safc-suitable/
260 a tank, so you're losing about $20-$30/tank
Buy the ECU you have on the list and think of the money you're saving on fuel as paying it off.
Stuff the SAFC, it may do what you want but don't bother.
Looking at your list :
RacingHart Type CR 18' Wheels - CAN WAIT
Sydneykid Handling Kit - CAN WAIT
Bigger Injectors - CAN WAIT
Z32 AFM - CAN WAIT
EMU Unit (Haltech or Apexi) **** Do It Now ******
Subtle Body Kit - CAN WAIT
Respray in "Midnight Blue III" - CAN WAIT
Rebuild with go faster bits - CAN WAIT
Hello 450kms or more per tank and shit loads of power
https://www.sau.com.au/forums/topic/170537-safc-suitable/#findComment-3149353
Yep, safc should be fine for your current target as your going to be restricted by your afm and injectors anyway. At least you'll know your engine is running the right afr's rather than um'ing and arr'ing to weather the stock ecu will cope.
The safc won't require that much of tune either as you'll probably only need 12psi to push the 200rwkW mark.
https://www.sau.com.au/forums/topic/170537-safc-suitable/#findComment-3149535
but then again, thre will always be someone in the market for a second hand safc... remember this. they still sell. its like a good entry point, no doubt that u guys might of had one to play around with before u went with the EMU's.
https://www.sau.com.au/forums/topic/170537-safc-suitable/#findComment-3150063
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
