iv got an r33 with rb25t, 221kw at wheels. iv bought a oil catch can/tank believing it would make my car run more efficiant and give me better performance... it has an inlet and outlet of 6mm and holds approximatly 400ml.
Can anyone tell me if iv wasted my money or are they worth putting in? also is it big enough??? and what do you think of them?
cheers
https://www.sau.com.au/forums/topic/171137-oil-catch-canstanks/
6mm is pretty small, you dont want to restrict the breathing system, its designed for stockish power levels which you arent at. you could of course still use it, but i would think about getting some bigger nipples on it
EDIT: are you sure they are only 6 mm? you want something at least as big as the hoses on the rocker covers ideally
Edited by jeffworld2
The part is titled well - the purpose it to catch oil from the engine. Usually not a problem unless you are on the track. Won't improve your performance but will keep you engine bay cleaner. Not a waste of money if you ever plan to take you car on a track.
for what sort of power im pushing out 221kw what is the recommended size i should use? is the 400ml compacity big enough?
yes it is 6mm i bought it not knowing what size inlet/outlet it had. silly i know
best is 500 to 1l with 15mm ports, plus it does help any engine that sees high revs every now again it doesnt just have to be track specific, that way you can see if it is breathing heavily or not. Plus this might get closed with "Been covered many times please use the search function" which is true but there ya go theres a start
Cheers]
A
Cheers]
A
new to this.
i will keep that in mind... thanks
just dont make anything smaller than it already is. have a look at the gtr breather hoses and see they are a lot bigger than the gtst from factory.
you dont need to change whats on your rocker covers, but try and keep the same or larger diameter through your catch can too. 400ml is not a lot, but your car probably wont spit a whole lot out so that should be fine. the catch can is there to stop the oil that is in the air in the cam covers from going into the intake, where it will go through to the cylinders and be burnt along with the air and petrol. oil in the intake can rob power if excessive, but more importantly can promote detonation, pinging, knocking etc its all the same to you it equals bad news. so you use a catch can to try and seperate the oil from the air (fill it with steel wool in a stocking etc. if you can open it). If it has a small filter venting to atmosphere, then it is a defect in nsw and will coat everything around it with a fine mist of oil unless you use it as an oil-air seperator (the steel wool idea).
if you use a smaller inlet/outlet pipe to the catch can than you have on the cam covers, at your power level you are risking increasing the crankcase pressure unnecessarily, which leads to dipsticks blowing out and cam cover gasket failure and a host of other problems if left unchecked.
keep everything sensibly sized and you will not have any problems.
just had a good read, that is an awesome thread. i feel sorry for the noobs at the end tho lol. mine is fully plumb back, so nice and legal (i hope)
i like the size of the inlets on the drift ones. thats what you really want, if only there was 3
newer drift ones I believe have three or at least two plus a plug you can use to vent to atmosphere or as a third fitting they are still small an sucky
best bet is to get one welded up or do yourself if u have the gear,n the skill got one welded up as I dont have a welder was cheapish and big so actually legal for drags etc.
will try n post pics when I get a chance was worth the stuff around I reckon
atmo FTW
Edited by noone
atmo FTW
excellent guys. you've been a great help. thanks
mine is "custom", about half the size of the stock windscreen wiper fluid dooby , its not pretty though lol. i will always plumb it back in, as that is just the law. i have a quick car but there is nothing i can really get done for. and i will try and keep it that way
i dunno what to do with the 1 i have then lol...
    • Well, apparently they do fit, however this wont be a problem if not because the car will be stationary while i do the suspension work. I was just going to use the 16's to roll the old girl around if I needed to. I just need to get the E90 back on the road first. Yes! I'm a believer! 🙌 So, I contacted them because the site kinda sucks and I was really confused about what I'd need. They put together a package for me and because I was spraying all the seat surfaces and not doing spot fixes I decided not to send them a headrest to colour match, I just used their colour on file (and it was spot on).  I got some heavy duty cleaner, 1L of colour, a small bottle of dye hardener and a small bottle of the dye top coat. I also got a spray gun as I needed a larger nozzle than the gun I had and it was only $40 extra. From memory the total was ~$450 ish. Its not cheap but the result is awesome. They did add repair bits and pieces to the quote originally and the cost came down significantly when I said I didn't need any repair products. I did it over a weekend. The only issues I had were my own; I forgot to mix the hardener into the dye two coats but I had enough dye for 2 more coats with the hardener. I also just used up all the dye because why not and i rushed the last coat which gave me some runs. Thankfully the runs are under the headrests. The gun pattern wasn't great, very round and would have been better if it was a line. It made it a little tricky to get consistent coverage and I think having done the extra coats probably helped conceal any coverage issues. I contacted them again a few months later so I could get our X5 done (who the f**k thought white leather was a good idea for a family car?!) and they said they had some training to do in Sydney and I could get a reduced rate on the leather fix in the X5 if I let them demo their product on our car. So I agreed. When I took Bec in the E39 to pick it up, I showed them the job I'd done in my car and they were all (students included) really impressed. Note that they said the runs I created could be fixed easily at the time with a brush or an air compressor gun. So, now with the two cars done I can absolutely recommend Colourlock.  I'll take pics of both interiors and create a new thread.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
