Yes ... Bonnets other than your factory ones are not approved. Reasons being they shatter during accidents, causing sharpnel type of injuries, crumple/bend zone is not there.
But there are some who swear by their CF bonnets that the 100% CF are actually much more tougher than factory OEM bonnets. This is really yet proven and documented.
Just my .5cts worth =)
  • Replies 56
Guest RedLineGTR
Thought that was true myself!!! but i doubt trying to explain it to the police :P
Guest RedLineGTR
hahahaa ... the prices on the website - $3,700.00 a pop for the dry CF bonnets
ermmm .... I think i would be better of getting a generic wet CF bonnet from Taiwan and use the rest of the money for a holiday or some other mods.
heehee
hahahaah lolz :P But in professional racing in Japan a bonnet that would weigh 2.2kg would be beneficial for track racing etc. Not that i would spend that much myself :(
OEM bonnets are designed to be part of the crumple zone which spreads an impact longer over time reducing the force on the passengers.
If the bonnet is weaker, it weakens the crumple zone.
If the bonnet is stronger, it wont crumple and will go through the windscreen taking your heads off with it.
I dont see the point really but thats just me. I dont have a purple atmo venting BOV either so I guess you can tell where I am coming from.
OEM bonnets are designed to be part of the crumple zone which speads an impact longer over time reducing the force on the passengers.
yes ya right. It all depends on each perspective and how ricey they wish their rides to be. No offense to those with such bonnets, because I also have the bonnet for my own and selling them too!!
Rice or not rice, I guess its also considered an art, just like drifting. you might be surprised at how artistic ricey some cars worldwide can grab your attention and leave you lingering with thoughts ... heheheheeee
my .5cts worth :P
well said. Also I've seen a few carbon fibre bonnets that don't have hinge locks/catches (can't think of their proper name). when the bonnnet is closed on most cars there is a small metal piece that sticks up into the bonnet next to the hinge mounts, if the car is in an accident they prevent the bonnet from flying back through the windscreen if the hinges fail.
some carbon fibre bonnets don't have the right holes in the underbonnnet frame work, so the catches don't do their job properly.
also, if your only after them for the wank factor I think supercheap and roughtobarn sell rolls of stick on carbon look plastic sheets like contact. :headspin: :wassup:
picked up a fibreglass bonnet today vented for $740. carbon fibre one was $1200, but its essentially just a fibreglass one with 3 carbon fibre skin layers... so its not really worth the extra $500 or so... so yeah... i guess you save on painting and thats it!!!
OMG ... FG going for 740!? With additional CF linings going for 1.2 large!? What car are your driving? R33??
This has been done a million and one times guys.......those bonnets are 1 layer c/f with the rest chopped strad and a plastic inner frame laminated on the inside.....In my opinion they are poorly laminated and dont offer ANY structural support what so ever......the genuine c/f bonnets from high class company's do what there made to do....and that is be extremly strong and very light....not just for looks.....and to those who say there not strong....what about a 34 GTR V spec II bonnet?There standard issue!Not to mention its commonly used on many supercars such as lambo's and ferrari....
I agree with Troy.
If you want one for looks, go for it, but don't kid yourself you are getting the benefits of C/F without dropping some serious coin.
I have spoken to the RTA signatories about C/F panels and bonnets. Yes they are illegal (unless factory fitted, obviously) and will require engineering (in NSW anyway).
Lucien.
bonnet pin or hood pins?
I dunno if your post was in response to my post, but seeing as it was straight after I'll assume it was....
I wasn't talking about anything at the front of the bonnet , but at the back where it's hinged. theres a small bit of metal on each side, next to the hinges which hooks into the bonnet framework.(on alot, but not all cars)
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
