Car:
1989 r32 skyline 4 door
Engine: rb20det
Induction: blitz pod,custom pod cover,fmic,
gates adjustable cam gears
slideing performance hiflowed turbo
Exhaust: 3" turbo back exhaust
Clutch: excedy hd clutch
Suspension: king lows in front
an standard in rear
front an rear strut braces
Wheels/Tyres: 18x8 blitz technospeed rims
silverstone evo 8 tyres
Interior: standard trim
blitz boost gauge
oil an water temp gauges
a/f ratio gauge
Stereo:
audio master head unit
alpine 6" fronts an rears
alpine 4 channel
exterior: custom orange with gold flack paint
full vertex body kit
the car is fully engineered
also comes with spare rb20 engine an turbo also with rb30 bottom end
price 12,800 ono
cheers Rob
Edited by orange_rob
https://www.sau.com.au/forums/topic/171820-fs-r32-4door-skyline-nsw/
