Hey all, I just took the 'stock' (or at least I think it is) turbo off my rb20... and when I compared it to the turbo that I have been told is from a Rb25, I noticed something strange.
The compressor wheel on the Rb25 turbo is bigger as expected... however, when I look at the exhaust wheels, the rb20 turbo appears to have a larger exhaust wheel... why would this be?
I would have expected the rb25 would have been bigger at the exhaust wheel as well due to having more gasses passing thru it due to being bolted onto a bigger engine.
I've included pics, can anyone shed some light on this?
Also, when I took the rb20 turbo off, some coolant came out of the dump pipe... again, should this be a concern?
Thanks in advance
RB20 turbo on RHS in this pic:
RB20 turbo on LHS in this pic:
Edited by retox
https://www.sau.com.au/forums/topic/172063-turbo-help/
That's weird.
I noticed that the compressor blades are completely different too. I thought they would just be bigger on the RB25's.
Perhaps the turbo on your RB20 has had a rebuild and the exhaust side of the turbo housing has been replaced?
I'm not turbo pro but it is the only thing that seems logical about it.
Have you been able to get your hands on another turbo from a RB20.
Keep us posted
https://www.sau.com.au/forums/topic/172063-turbo-help/#findComment-3169771
Was given this reply on another forum:
look att he angle if the fins on the rear turbine side of the turbo's.... the RB20 one has pretty big gaps allowing the exhaust gas to spin the blades easier being on a smaller motor... The RB25 has them closer together to restrict it a bit so it doesnt spool up early. From the pics tho the Rb20 exhaust wheel does appear bigger... Only one way to find out and measure them. Also the Rb20 rear looks newish and the 25 oldish if that makes sense could possibly have been a hi flow... U never know with a second hand turbo unless u measure it all up and know exactly what ur looking for lol.
Liam
does this sound right?... seriosuly lost now as to which would be better on the motor!!!
https://www.sau.com.au/forums/topic/172063-turbo-help/#findComment-3170073
If it has been hi-flowed, wouldnt the compressor wheel be increased in size as well?... not sure.. still new to this turbo business :)
Either ways, hi-flow rb20 item vs stock rb25 item... which would be the better go-er on the RB20?
Also, as mentioned, I'm pretty sure some coolant came out past the exhaust wheel on the rb20 turbo when I was taking it off the motor... should I be concerned about that?
appreciate your input guys :P
https://www.sau.com.au/forums/topic/172063-turbo-help/#findComment-3170118
Turn the turbos round sideways and compare the iron bearing housings , the later R32 RB20 turbos should be ball bearing and the middle is larger in diametre or fatter if you like . If your RB20 one is skinnier and its exhaust housing bolts are on a smaller pitch circle diametre then its probably an early R31 RB20 bush bearing turbo . These used much smaller compressors in an attempt to spool them early . From memory the exhaust housing A/R was very small and they're not much good for anything .
The Hitachi BB ceramic turbos have a small bolt head in the side of the bearing housing , general consensus is that its some sort of bearing pre load device but anyway only the BB Hitachi's had them - from what I've seen anyway .
Cheers A .
https://www.sau.com.au/forums/topic/172063-turbo-help/#findComment-3170234
I can't beleive no one's said it yet, but from the top pic, theyr'e both rb20 turbos. nissan motor 16v.
One of them may be the earlier bastardised vg30 with the nissan 16v comp cover, and non op6 rear housing. We'd need more pics of the back housing numbers, and the wheel up closer.
edit: oops, you guys beat me to it. haha
Edited by MANWHORE
https://www.sau.com.au/forums/topic/172063-turbo-help/#findComment-3170338
ok, got some better pics.
New Turbo (larger compressor wheel):
Markings on exhaust housing: 5173 near flange, 04U, 8. <--- on front (compressor side) of housing. Nothing on back
Old Turbo (Smaller compressor wheel):
Markings on exhaust housing: looks like 0074 (or A) near flange, 2, 8. <--- on front (compressor side) of housing. On rear (exhaust side of housing): B, 59S
Sorry about quality of pics - camera phone
Edited by retox
https://www.sau.com.au/forums/topic/172063-turbo-help/#findComment-3170356
    • Hi from Canada, Both of my calipers are starting to fail. My car is a 2005 M35 Stagea ARX and I can't seem to find any parts or any cross reference caliper that would fit my car. Is there a company or a similar caliper that would fit and I could replace the OEM one. Or if anyone knows where I can find a new OEM. Any help is very appreciated. Let me know!
    • Maf is a question mark but TPS  I have set at 0.47, the fact that I’m getting proper voltage range out of it with the key on leads me to believe it’s functioning properly. I’m getting proper voltages on basically everything. I still need to look up voltage ranges for z32 maf and test that
    • Honestly no not at all, but it’s a very basic tune, it’s stock injectors q45 tps and z32 maf. Other than that it’s a completely stock base map. The file is from nistune and from my understanding if it was tune related I would be able to unplug maf and tps and it would still start even if it was a really shitty start. I have tried starting it with coolant temp, maf, and tps unplugged none of those 3 togethor or individually changes anything
    • 🏆 Skyline Supremacy Meets Mount Panorama Magic 🏆 Join SAU NSW as we take the long way to Bathurst, the home of GTR greatness. Saturday 30th August 2025 7:00AM Meeting Hanna Park North Richmond 7:30AM Departure Cruise Via Bells of Line Road 9:00AM Arrival to Stop 1: Golden Poplars Meadow Flat 9:45AM Arrival to Final Destination: Mount Panorama Motor Racing Circuit Meet Location: Hanna Park North Richmond Stop 1: Golden Poplars Meadow Flat Final Destination: Mount Panorama Motor Racing Circuit   *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day   Highway gets as low as 10l/100km on my end so I'm not as worried about it being a mechanical issue. More likely just the tune on the haltech.
