Hi guys my name is luke i just brought a 1993 R32 gts-t it has minor mods.... exhaust,pod filters,
I would like some help
1. were can i get those awsome nismo gagues
2. is the gtr gear box stronger than the stock one
3. will a rb26 head bolt stright on the rb20 block
im only planing a few lil mods im aiming for 300rwhp
cheers luke
https://www.sau.com.au/forums/topic/172158-im-new/
1. What awesome nismo gauges? are you talking 300km/h speedo or something?
2. GTR gearbox has a transfer case for the 4wd. An upgrade for you RB20 box is an RB25 box out of an R33.
3. I doubt a 26 head will fit and why would you want to? 300rwhp out of an RB20 would need more fuel, bigger turbo, bigger injectors, management etc. Would be easier to start with an RB25..
Just to give you a bit of an example.. my car has a front mount cooler, split dump pipe, 3" exhaust and an RB25 turbo running 12.5psi. As far as engine work, this is all I'm doing to the RB20. I am saving up for a 25 engine/box/halfcut as the money on new turbo etc would be better spent with better gains on the RB25.
https://www.sau.com.au/forums/topic/172158-im-new/#findComment-3173996
cheers luke
Hey Luke
Best replacement for an RB20 gearbox would be an RB25 as bubba said.
As far as getting 300rwhp goes, its fairly achievable but just depends how much you want to spend.
I'm going to be aiming for the same sort of power and this is a rough idea what you would need.
- Bigger turbo, and there is a forum member, SLIDE, that does awesome highflows for a great price. That will be enough to get you there. http://www.skylinesaustralia.com/forums/in...howtopic=153972
- 3" turbo back exhaust, could easily find on 2nd hand on the forums
- Bigger fuel pump, also can be found on the forums. Cheap replacement like a WALBRO, or something decent like a 2nd hand GTR pump, or a BOSCH 040 is pretty cheap new these days (roughly $240), will be sufficient.
- Front mount intercooler. There are some alright kits going on the forums. Justjap do one for $345 + postage. 600x300, that includes all the piping. Pretty good upgrade.
- Some type of engine management, so either getting the standard ECU retuned, or getting a Power FC for example, or a WOLF, HALTECH etc etc that will do the job! Plug and play is probably the best option, so something like WOLF 3d or a PFC, as you wont have to pay for installtion, and you can use all your existing sensors without chopping up your loom.
Stock injectors will take you there, and an aftermarket clutch wouldnt hurt. Something like an EXEDY HD brass buttom can take up to 300rwkw, will set you back about $400- $500 new off the forums. Not installed obviously.
RB20 box will be strong enough, depends how you treat it, same with stock clutch.
Have a read of the thread below, it shows some power figures for RB20's and the modifications done to achieve those figures. Will give you a good idea of what works, and what doesnt.
http://www.skylinesaustralia.com/forums/in...howtopic=103095
Just a bit of information that is useful, IMO. Good luck with it all, keep us posted.
Abu
Edited by abu
https://www.sau.com.au/forums/topic/172158-im-new/#findComment-3175254
sorry guys i havent been on in a while the pc had a virus anyways there mite be change of plans if the bank says yes mite be spending a lil bit more money on a R32 gtr :( my dream car but were can i get those nismo gagues from that says 300kms on tham i dont like the 180kms ones cheers
https://www.sau.com.au/forums/topic/172158-im-new/#findComment-3187758
  • 3 weeks later...
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
