Hmm so after some pondering ive decided to go for a S-AFC II, FMIC and fuel pump. And then in the near future hopefully a slide high flow.
From what ive read in old topics the SAFC can't really support bigger injectors, but would support a high flow yeah?
Still undecided on what pump to get, Walbro is deliciously cheap but people seem to have had issues with it. Was also going to get a Bosch 040 but aparently its crap and noisy :D
the SAFC isnt going to handle the high flow turbo very well. you'll be able to tune it slightly, but you'll be missing out on somewhere between 30 and 50rwkw from the lack of an ECU once you put a aftermarket / hiflow turbo in. Plus stock injectors cant cope with much more than ~225 rwkw.
The SAFC isnt a bad option, as it will hold its value, so when you put in an aftermarket ECU, can sell it for same price you buy it. Nothing wrong with the Bosch 040 if its installed properly. can just hear it over exhaust at idle, and you cant hear it at all once you start driving.
As i said in my previous post however, make sure you have set aside money for a clutch, especially if your still running stockers.. it aint gonna last long. might just be able to squeeze that into your 2k budget along with fmic, fuel pump and safc2.
Still undecided on what pump to get, Walbro is deliciously cheap but people seem to have had issues with it. Was also going to get a Bosch 040 but aparently its crap and noisy :)
You can always sell the safc should you want to change the ecu down the track, but it will be more than adequate for the standard hi-flow and won't loose you 30-50rwkW as stated earlier. In the dyno results thread people are running hi-flows with stock ecu and achieving 200-220rwkW, it's just a safer idea to get it tuned with the safc.
Find a genuine walbro pump with the higher L/min rating or a Denso pump from Kudos motorsport. 040's are a good pump put they're just physically to big for the r33 tank and if it's touching one side of the tank it will be noisy as hell.
When you say a walbro pump with the higher L/min rating, which one would that be? Only ones I see on ebay are the 255L/hour jobbies, the Walbro GSS 341. That the one your talking to or is there a model up from that? I WOULD like to go with the Walbro mainly because they seem easy to source and are one of the less expensive pumps around.
One is a GSS341 and the other is a GSS341HP, most dodgy traders sell people the GSS341 which is fine for standard cars, but for modified and larger capacity cars the GSS341HP(High Pressure) is required.
Sorry by l/min I mean't l/hr... brain lapse :) .
Edited by BAMR33
Hey not hijacking the thread but let me know how u go as i have similar mods to you and am in the same boat.. got full exhaust, boost controller and got same sorta money to play with. But i have splitfires and a h/d clutch as well:)
So the safc's are actually worth it? And i (and Lachlan33) would feel a noticeable difference with the addition of a tuned safc and a bigger fuel pump? I'm also debating whether to get a justjap or a hybrid cooler for mine.
Walbro's low pressure pump in this design is part number GSS315. GSS341 is the high pressure variant.
get swaybars and some coilovers, and maybe some castor rods if the budget can stretch that far ;)
Then you can corner faster and out run all the guys with stock suspension and 200rwkw :)
what he said, but forget castor rods :nyaanyaa: or enkei rims ;)
Whats the most important thing to you?
Is it "bling/rice'?
Is it better safety (the standard gtst needs some help with traction)?
Is it straight line accelleration?
Is it reliabillity?
Depending on how you answer these sorts of questions you will get some slightly different answers.
Remember that search is your friend.
If you are handy with a spanner the $2k goes alot further.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
