Melb Auto Salon 2003 Entrants (Put your name down if you want to be on the stand)
pm ur details and details of ur car
ill speak to james and see wats the go
its certainly not too late but the entry is now 200
if u had it in by last friday it was only 100
its ur choice
we are gonna have a great stand and need a yellow 34
so would be great to have ur car
Well, it's official. Leewah is out of MAS as I just found out today that it's gonna take 10 days for my new goodies to arrive from Japan which gives bugger all time to put the car back together and tune.
I apologise for pulling out but if I can be of any help during the MAS weekend, I'm happy to help. If we need ppl on the stand, I'm more than willing to be there all weekend as I've prioritised this weekend all to MAS.
look guys thankx for all the help
just spoke to james and we decided to leave it
if i can put the car in mas somehow or can still be bothered you will see it there somewhere
good luck too all
hope you go well
ambz thanks alot
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
