Firstly let me say hi! i am new on these forums and have just purchased myself a very neat R33 GTST - and needless to say am a happy as can be!
Was hoping a few knowledgable people could help with a question i have about my rear camber..
As my car has been lowered with new coilovers, my rear camber has been thrown out a lot and now the tyres sit like this /----\ (lol..) and i am a bit unsure as to what kits are available / best suited for my car.
MRT in rhodes are telling me to go with a Whiteline adjustable kit.. though i am not sure on the specs yet.
I have done a quick search about camber kits but i am at a bit of a loss because suspension is realy not my forte' :)
Thanks in advance dudes, and i will surely see some of you on the upcoming events!
https://www.sau.com.au/forums/topic/172879-lowered-camber/
How low is the car? Centre of wheel to guard? If it is around 340mm, you can correct the camber using the Whiteline adjustable bushes ($135RRP) as they offer +/-0.75deg adjustment. If the car is lower than this, you can either get 2 camber kits (bushes for both inner and outer joints of the arms) or you can buy the Whiteline adjustable upper arms ($300RRP from Autobarn) which offer a lot more adjustment.
If you just want the bushes, have a look in the groupbuy section, "Sydneykid" is running groupbuys for Whiteline/Bilstein/Eibach/Noltec stuff.
https://www.sau.com.au/forums/topic/172879-lowered-camber/#findComment-3182206
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
    • I'm interested,do you still have it?
