  • Replies 44
I was there pretty much till the end too. When all the cars around me pretty much left, I decided to go also. Most of the car park was empty by that time. I was parked across that midnight purple GTR. Pretty awesome car. I think my car was filmed randomly, starting from when I was coming into the car park, so will be interesting to see. Once again though, I think I had the only V35 there... :thumbsup:. Ah wells, hehe.
Was that your V35 that I parked behind, Russky? I was in the dark green Stagea (probably also the only one there) and I parked next to AboBob Adam's white R34 sedan.
I am not sure... I was parked with my nose in, left to me was a bmw at the end of the night (civic was first there), and 180sx from memory was to my right. In front of me was a silvia. I was in the same row as the 200sx with its engine bay open the whole night (I think its the Ignition project car. Correct me if I am wrong). I remember the white R34 sedan. So maybe? hehe.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
