Im sure the cops have got better things to do then make up speeding fines
You're right. They should be out there defecting you for having an uncovered pod filter.
if they give u a speeding ticket do u really think they are going to risk losing their job for somebody they dont know?????
What the cop thinks is only partially relevant. What they can prove, based on the rules of evidence, should be all that matters when it comes to handing someone an infringement.
So, what evidence do they have? Speed detection devices require the device itself to be stationary. They have to tail someone in a car with a recently calibrated speedo for a certain length of time in order to book them for speeding without a detector. They can issue an estimated speed, but as they're judging from a moving vehicle that puts their perception in a non-constant frame of reference.
That said, you'd have to go to court to contest it. The guy needs to weigh up the cost and inconvenience of legal action (and the potential for losing) vs just paying it and moving on. If it means losing a license then yeah, by all means. But if its a first offense.....you could probably just write a letter to the RTA and get let off with a warning.
hey sorry to hear bout the fine they suck lol
i live in adelaide n around a couple months ago got done oin 64 in a 50 zone..thought i was doing the right thing and goin a tad over 60 but just found out south terrace is a 50 zone :(
i coped a $179 fine for 14 km/h over speed limit and thank god my dad took the points coz it was my first fine and i would have lost my P's :D
so im guessin 20km/h over speed limit would be around the $300 mark.
and yes cops can get u while there car is moving as well as stationary..bloudy cops lol
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
