I just want to know if the nismo mounts [or any mounts for that matter] are smaller diameter than the std nissan mounts. I'm particularly interested in the right hand or exhaust side front mount. I had to cut into mine to fit my GT3076 WG turbo on a HKS cast low mount manifold. I reckon I cut too much off and plan to replace the engine mount, but thought if I was going to do it that I should get something that is bigger/better/brighter - well not so big in this case.
https://www.sau.com.au/forums/topic/174141-nismo-engine-mounts/
Yeah, thanks, others have ground their engine mounts back as well. I originally got the angle of my cut wrong and cut parallel to the motor. The cut really [now I know] has to go more like 60 degrees to the motor. Its a problem when using the HKS and a bigger turbo.
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
