Hi, guys im farely new i do alot of research just want some opinions on my r33
im running stock R33 Gts-T Jap cat, 3inch cat back , Auto
Mods Done So far New Spark Plugs
3inch cat back, jap cat, and pod filter
i done the 2nd stage boost fix were i can get boost at 2.5krpm instead of 4.5k rpm full bost
Boost Sits just above the quarter line under the 7+ on stock gauge
i wann spend about 2k just to begin with
How much kw at wheels do i have ruffley with my mods
and how much rwk will i have with 2grand budget to begin with
https://www.sau.com.au/forums/topic/174643-new-r33-gts-t-95model-s15/
hey mate, i would say get a dump and front pipe along with a high flow cat to finish off the exhaust. You should see some good gains just from that. Up the boost a little to a safe level (a cheap bleed valve will do the job), you should also get a front mount at the same time. Also a computer would be good..something like an apexi power fc is out of your 2k budget so maybe an apexi afc neo would be good to do the fine tuning. :yes:
My car has the exact same mods as yours (compliance cat, 3 inch catback, highflow panel) and im making 148.5rwkw.
my next mod was gonna be a highflow cat + 3 inch front/dump pipe. complete your exhaust dood. its good for approx 15-20kw. approx a grand gone there
with the rest get that fmic and boost conrtoller and a good boost guage. up the boost to about 11psi (you'll already be running 9 once you put the fmic and full zorst on). $800 ish
you'll have 200 bux or thereabouts left from that. get a cold air intake box for your pod. atm you are gonna be making less power than my stock box with panel cos your pod is sucking hot engine bay air
i'd say once you're done with this lot you'd have about 170rwkw. keeping in mind that our cars lose power cos of the auto box thats a pretty good power value.
If you take the time to read the Forced Induction Guide
http://www.skylinesaustralia.com/forums/in...showtopic=66556
And mainly this thread entitiled, what mods to do first
http://www.skylinesaustralia.com/forums/in...showtopic=45218
It should put you well on your way
    • Hopefully it ends up being something manageable, like a hone, rather than a full bore—it would be a huge relief if it’s not as bad as it looks. Hang in there; these setbacks are annoying, but it sounds like you’re handling it as smartly as possible.
    • At the end of the day, it’s all about understanding the odds and being comfortable with the potential cost, whether it’s horsepower on a build or chips on a roulette table. And I have to say, the Laine example made me laugh—some people really do embrace that carefree, “roll and see” attitude!
    • Thanks MBS206, i got that PDF but got abit overhelm with all the connections and tracing of wires. I wasn't expecting to plug the dash harness anywhere. i was just going to use my electronics jumper wires to plug into the right pins like ECU power, ecu ground, ignition trigger etc... I do have a few ratchet straps locking it down tight. Fire extinguisher ready and only a small amount of fuel at a time, enough to submerge the pump.
    • Thanks GTSBoy, i will do abit more digging. I am missing a blue relay near the ECU connector... so i will chase that up in the next few days as well
    • https://yariksteel.ru/manual/R33/Skyline_R33_elektroprovodka.pdf   Page 18 should be what you want for the Dash Cluster wiring. Though, you don't need the dash plugged in to get the motor running. What you want is power as how GTSBoy said. You need to power the ECU. Find in the above link the ECU pin outs (Verify them before just connecting them up from things written on the internet). Find anything needing power, give it power, find anything needing ground, give it ground. Then give the starter motor power through a big cable, and bridge the solenoid on the starter straight to power too.  ECU will be on, and when you give the starter power, it'll spin the starter motor, and it should start. I also hope you have a proper stand, and not just the engine sitting on some wood. You will want it bolted down properly.
