Hello all,
Organising a meet and movie to see 2 Fast 2 Furious @ Dandy Drive ins on the 21st of June... Lets make this a big one! Tell one tell all.
Gonna follow the plan from the last drive ins cruise so meet at Dandenong Stock Yards @ 6pm, meet & chat then onto the movie @ 7:30 (starts at 8:30 - gates open 1 hour early).
I recommend that people bring food and drink because stuff is quite expensive there (unless Vickii brings us all food again :P).
I will speak to the cops before hand and promise good behaviour in exchange for no trouble. It was fine last time. And from what I have heard there was no trouble at Coburg on opening night.
Let us know if you're coming. Do people need directions again?
Coming so far (assuming cops don't bother us):
- MaXiMuS007 (with his car back)
- HotSky
- DJ_L3ThAL
- MzDeFecTeD
- 32_envy
Interested:
-RedLineGTR
-Al
(P.S. Not hijacking JET-33's gold class nite, but drive ins are cooler so come to both!)
its awesome
the 34 is fkn NUTZ!
even if u ring the cops, it doesnt matter, theyl just say theyl leave u alone and b there in unmarked cars/clothing...take down plates..and send out letters...
especially at dandy...its like a few kms from the illegal drags which they r currently goin double nuttz on and im tippin its a sat nite too..?
hmmmmmmmmmmmmmmmmmmmmmmm
Hrmm so is any1 still coming?
The whole point of this for me was to celebrate getting my car back but as that has been delayed i'm not even in the mood to go any more *cry*
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
