  • Replies 453
Posted Images
Interlooper/SNISMO:
we are meeting Eatan8 on torquay rd/Surf Coast HWY (see map).
if u guys like, pm me your mobile numbers, when we leave the meet point near avalon, i will msg you that we have left and we should arrive in this location (map) within 25-35mins (traffic depending)
let me know if this helps you guys out, i know you dont wanna double the travel distance as you live on the side of where we are travelling. so let me know.
Edited by cheez
Interloper/SNISMO:
yup, that location suits me fine. Thats where i met the group on the last official cruise.
well interloper, send me ur mobile number and as with eatan8 ill msg u when we on our way there so your not sitting around waiting too long.
I'll join in here as well. PM sent.
just a little note for those who would like to head up with myself and dilmah we will meet at stud park shopping center in the warehouse carpark at 6:45ish and will leave sharp 7am to make it for the pre meet at campbellfield kmart.
thanks
Ash
okily dokily :)
Sure, just agree to pre-pre-meets.. :<
You know you have to pick up the other 'noob' too? So.. set alarms for 4am? :laughing-smiley-014:
Edit: Might not have to pick up other noob. :>
Edited by rh1n0
