  • Replies 453
Posted Images
how about u bring your ns mates along to this cruise DieMz cause lets face it yous cant beat our cruise so mite aswell join us :) lol nah just joking but yeh it should be fun sau and ns cruise not to mention MASSIVE
sounds like there's going to be just as many boats on the road as there will be in the ocean.
sorry... couldn't resist :)
lol idiot
YAY for massive cruise
@black GTST its all good mate.
^hahahahahaha
yeah its probably easier is we all meet up at the same place, will be convenient for all members, ill be the 'ethnic' looking fella in the blue 32 :)
i dont know many of u by name/face so dont be scared to say hi :)
plus ill keep the ns boys briefed.
we were thinking of going up this weekend, but what the hell, might as well wait another week
sunday it is :)
Edited by DjeMz
Im coming in my R33 and my best friends coming in her R33 too...
we both live in the west...is there a wst meet point somewhere??
pm sent ferah.
your now added to the list which i belive makes 50 cars confirmed, plus NS and any others that show on the day, we looking at 70+ cars. :thumbsup:
Also just heard the the Soarer club are oganising a cruise on the same day as this to Lorne......gonna be lots of imports round the coast on the day!!
Its actually Toymods that have the cruise but its been posted on soarer forum too, there leaving at 11am from Winchelsea BP.
http://www.toymods.net/forums/showthread.php?t=25443
http://soarercentral.com/sc-forum/messages...html?1188213069
Im guessing once the first big group comes through the local cops will be alert then the next big cruise will come through and then :D
LoL might be a stupid question...
but do u have 2 have a skyline 2 come??
dont have to have a skyline to come. its an all in cruise. theres gonna be mainly lines, but a couple of stageas, some silvias and a few others.
but majority, not all, will be skylines. if some1 who doesnt have a skyline wants to come by all means.
im gettin pretty pumped for this! hope to god its a mad day like we have been getting!
ashneel n dilmah looks like im meetin you guys bright and early, noone from narre area wants to cruise over wit me! :blink:
chEErz!
brett
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
