  • Replies 453
Posted Images
awesome man, we'll have our own mini cruise before the main event. should be a blast!
I still get a thrill just driving alongside other random skylines on the road.... i'm yet to give anyone a wave though... don't want to look like a knob.. but if they had a SAU sticker I may.
anyway, i digress. we'll keep in touch via PM as it gets close to the day.
ashneel n dilmah looks like im meetin you guys bright and early, noone from narre area wants to cruise over wit me! :blink:
list updated guys.
dont think would be wise to invite the soarer club, as they will be meetin in winchelsea @ 11, we leaving at 10:30 in geelong, too much distance and not enough time. its gonna be hard enough keeping 50-70cars all together. may need more help on the day, see how it goes in the morning.
countdown is on..
man dan with that many cars i dear say the cops are going to show ;) and if that happen's my day will be rurended :spank: .
also i emailed ignition dvd in a late minute hope they will come down and film the event esperly since they haven't done a melbourne hot spot.
every one email ignition dvd about the cruise and tell them to come down ;):)
[email protected]
chears brentt
[email protected]
chears brentt
if the cops show well what can u do, but if its anything like the last cruise, we never had issues. the only issue i am facing is the photo shot on apollo bay pier. its gonna be real hard to get that many cars onto the pier at one time, plus will take a while to get them lined up for the photo. might call the local council and ask permisson before we do it, or do it in 2 bunches. like 25 cars at a time, take like 20mins for each photo.
ive added my phone number to the original post. please note it and if any1 is running late msg or call me and i will have the cruise wait for you. i wont wait 30-40mins coz u slept in but i will wait up to an extra 15mins.
Might have to try and get my car Rego'd before Friday next week rather than Monday.
Hmm, tough call but you never know ;)
admins and mods are more than welcome to come along. this way we can meet you in person.
man dan with that many cars i dear say the cops are going to show ;) and if that happen's my day will be rurended :) .
LOL im sure they'll have plenty of other cars to defect before yours champ
Holy cra#p this is getting big! I havent been on hear for a while and i remember when there was only a few of us myself included. I think my bro is his s15 will come too. :D
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
