stock '93 r32 front bar. $100 neg
bar is in good condition, just needs a quick sand and paint as paint is flaking. (nice prep and paint work whoever did it!!!)
colour is gunmetal grey
ALSO available is factory front driving lights with all brackets/bolts etc. $90
pickup
Mt. Gravatt
BRISBANE 4122
Edited by Rossman
https://www.sau.com.au/forums/topic/175304-r32-front-bar/
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
